windshield wipers not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2008, 05:03 PM   #1 (permalink)
View 2001 Camry's Photo Gallery
The girlfriend had someone pull out in front of her again today. I went to where she was at so she could use my truck to get back to work. I am not familiar with the car I got in and drove it home but the windshield wipers wouldnt work at all. After I got it home I checked all the fuses the ones under the dash and under the hood. I couldnt find any bad fuses is there another fuse block or something else I should be looking for? I did notice after checking the fuses the wipers would work if you pull the lever that turns on the washer and and wipers at the same time. I would like to get this fixed so I can drive it to the body shop its raining sideways right now.
2001 Camry is offline   Reply With Quote
Old 01-31-2008, 05:07 PM   #2 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
i had the same problem, turns out the nuts holding the wiper arms on were loose, so try tightening them down.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 01-31-2008, 05:12 PM   #3 (permalink)
That was quick I just posted this less than 5 minutes ago. I will check that but I dont think that is the problem since they do work when you hit the washer switch. I will let you know in about 5 minutes
Old 01-31-2008, 05:15 PM   #4 (permalink)
The bolts are really tight. I think its an electrical issue.
Old 01-31-2008, 05:16 PM   #5 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
another problem might be a loose wire under your fuse in the dash. Take out the wiper fuse and see if there is a wire there. Mine had the wiper motor ground wire wrapped around the fuse base, so it needs to make a good solid connection there to work.
[U]
Old 01-31-2008, 05:16 PM   #6 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
edit: my bad, not the ground
[U]
