Bad light indicator lit on dashboard for rear bulbs but bulbs fine???????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2008, 12:15 PM   #1 (permalink)
View steppinthrax's Photo Gallery
I have a 99 camry. I got a bad lamp indicator for the rear lamps. I could see it was the rear because when I started my car and let it run and then hit my brakes the bad lamp indicator comes on. I tried hitting my headlights first but no bad indicator until I hit my brakes. I pulled out the lights from the trunk and they are FINE!!!!! I looked closer and both bulbs are in good condition????
WTF.
steppinthrax is offline   Reply With Quote
Old 02-01-2008, 01:32 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I understand that the light sensor unit works by checking the resistance of a circuit. If the sensor is good (95 is in the trunk behind the carpet on the driverside) then something is causing increased resistance. Coroded wire, broken wire, rusty socket, bad ground, bad bulb. A bulb might still light up in a bad circuit. I wouldn't focus on just the tail lights go ahead and check the rest. Check the base of the bulb and the socket for corosion. I have found a battery terminal wire brush works very well to clean the larger bulb bases and sockets.
Kep
Old 02-01-2008, 01:37 PM   #3 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Commonly over-looked problem is the 3rd brake light. Even if it works follow Kep's advice and pull the cover.
Dave's is offline   Reply With Quote
Old 02-01-2008, 04:48 PM   #4 (permalink)
YOUR THE MAN
I didn't think of that. Went out to my car after work. Put a board of wood to prop the brake pedal closed. And yes, the 3rd (high top) brake light was out. I can't believe I missed that.
Thank You
Old 02-01-2008, 08:16 PM   #5 (permalink)
vL
92Camry5sp's Avatar
Gameroom cash: $219005
iTrader Score: 6 reviews
View 92Camry5sp's Photo Gallery
i have this problem on my gen 3. my 3rd brake light is not out. all my brake lights work. i even clean the bulb sockets and i still have the light indicator lit. any other advice?
92Camry5sp is online now   Reply With Quote
Old 02-02-2008, 08:26 AM   #6 (permalink)
Dave's
If you've cleaned up all the sockets (including the 3rd brake light) then like Kep said, there's a sensor which is probably located behind the carpet in the trunk near the driver's side hinge. Mine's a yellow box. Had an intermittent problem which was a slightly burnt socket on that 3rd brake light. Really had to polish it up and install a new bulb to finally solve it.
P.S. Thanx steppinthrax- glad our advice sometimes helps people.
Old 02-02-2008, 09:52 AM   #7 (permalink)
I know a lot of the brake light bulbs have double filaments so the bulb can still work but one of the filaments burnt out. That can trip that sensor as well i imagine.
Old 02-02-2008, 11:54 PM   #8 (permalink)
View stroise's Photo Gallery
i have the same issue with my grandpas car. the failure warning sensor in the trunk cost $300. i didnt get it. i bought a bulb for the 3rd window brake light. his sensor went on when the bulb went out but i replaced it with a auto parts store bulb. it worked but the resistance in the bulb is probably wrong causing the light on the dash to go on. i havent put the bulb in yet cause of the bad weather here. im gonna do it tomorrow and hopefully his amber light goes out. i have a question. if this dummy light stays on will he pass his emissions state inspection test new york area. or if this lite stays on can he fail.
stroise is offline   Reply With Quote
Old 02-03-2008, 06:33 AM   #9 (permalink)
View tarbasd's Photo Gallery
3rd Generation
I don't live in NY, but it would really surprise me if this had any effect on the outcome of the emission test. Unless it also contains a safety test.
tarbasd is offline   Reply With Quote
Old 02-03-2008, 11:31 AM   #10 (permalink)
i went to the dealer friday. i bought the $3 bulb. i installed it today and the warning failure light is off. THank god its fixed. I cant believe how bulbs can be different from place to place. You can actually see a resister inside these bulbs to send a signal back to the cars computer to turn the damn failure warning light on. so if anyone is having issues with this amber light on the dash replace the bulbs that are out and get new bulbs from dealer. DOnt go to auto store. lights from the parts store might work but they arent the correct resistance for these cars.
Old 02-04-2008, 03:36 AM   #11 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
+1 My Camry always burns one of the filaments and drives me nuts
EvoFire is offline   Reply With Quote
Old 02-04-2008, 08:49 AM   #12 (permalink)
View solidg's Photo Gallery
4th Generation
just had 3 different bulbs burn out
i used bulbs from autozone
it made the dash light go out
the bulbs worked fine
00 camry 130,000
solidg is offline   Reply With Quote
Old 02-04-2008, 04:05 PM   #13 (permalink)
Kep
Kep's Avatar
If you go in to an auto parts store and look at all of the bulbs they have you will notice several different styles and each of those often have different resistances and colors so you need to go in knowing just which one you want. Just because a bulb fits into a socket doesn't mean it's the correct bulb. If you don't know the clerks can usually help. If you're lucky you can still read the info on the old bulb.
Kep
