93 Jerks when gas is pressed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2008, 03:58 PM   #1 (permalink)
View redace666's Photo Gallery
I have a 1993 camry and whenever the gas is near low or the last block on low whenever i press the gas for accelleration the car jerks like its starving for gas, but if i press the pedal extremely slowly it will accelerate, could it be the fuel pump? any advice could help, thank you!
redace666 is offline   Reply With Quote
Old 02-02-2008, 06:22 PM   #2 (permalink)
View Ravie_g's Photo Gallery
that should be normal,my brothers ES300 does same thing. and the pump IS starving if your on empty. press gas hard = fuel rush to back of tank, interrupt fuel pickup on pump.
TIP#134: Always make a note of the current speed limit on the road you are driving on. Just in case you need to slow down.
Ravie_g is offline   Reply With Quote
Old 02-02-2008, 07:32 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $198580
View xtremeskier97's Photo Gallery
Its because the little gas that is in there is sloshing around and going away from the pump at times. Its not good to run your tank that low. The pump will start to pick up all the crap at the bottom of your tank.
Resolution:
GET SOME GAS!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 02-02-2008, 07:49 PM   #4 (permalink)
whne i say low, i don't mean right beside empty, i mean like way before at least the block, im thinking its the fuel pump
Old 02-03-2008, 10:12 AM   #5 (permalink)
yup, get some gas, then check it out.
