Egr 0401 Light Went Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2008, 10:16 AM   #1 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Hey guys, a week ago my check engine light came on. So i took it to autozone and they told me it was p0401 egr valve insufficent flow. So I read up on it here and then just went and fiddled around with the egr and modulator hoses. Then i noticed the next day the light wasnt on anymore. Good luck? Im just wondering why it went out without me doing much?
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 02-04-2008, 10:47 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
it was probably just stuck closed due to carbon deposits and your jiggling jarred it loose....if you're lucky, it won't come back on for a while
HaHa
Old 02-04-2008, 10:55 AM   #3 (permalink)
View Typrus's Photo Gallery
The guys and gals of Autozone usually clear the codes they read...? If they are doing their job anyway.
1995 Camry 5-Speed 5SFE
Typrus is offline   Reply With Quote
Old 02-04-2008, 12:07 PM   #4 (permalink)
Dude Wheres My Car?
nukem678's Avatar
No the light was clearly on after i left autozone. I think i got lucky when i started playing with it.
Old 02-04-2008, 03:15 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Quit that! You weren't "playing" with it, you were "fixing" it!!! The fact that you got in there and fiddled with it is great. Most folks just take it in to a mechanic and have them fix it.
+1 for Eye8pussies. Now is a great time to research cleaning out the EGR and Modulator valves. Then when you have time, go ahead and do it. If your state has pollution inspections, do the throttle body, IAC valve, and PVC valve as well. Do the Sea Foam trinity (vaccum line, oil & gas) and you will probably be in very good shape.
Kep
Old 02-04-2008, 05:31 PM   #6 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
fuckin egr got it for about a year now and nuttin removed it twiced and sprayed tb and carb clearner down the metal pipe bolted on the egr and i resetted the ecu and ot can back! fucking egr
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 02-04-2008, 08:27 PM   #7 (permalink)
Kep
Kep's Avatar
Spray chemicals may not be enough. If it doesn't get clean you need to manually/mechanically remove the carbon without damaging anything or dropping chunks into the bottom. Also, don't forget the modulator and the vacuum hoses from the EGR to the modulator (mine was plugged almost solid). Also, don't forget the opening to the throttle body. No rest for the wicked--is your engine generating an excess of residue? Why? Just fixing the EGR may not be enough.
Kep
Old 02-04-2008, 09:07 PM   #8 (permalink)
Creeps228's Avatar
i have no idea but the vsv and the modulator are fine, i cleaned out the TB, just ask ASG14 and Eye8Pussies the second time i cleaned it it went away for a couple of miles and came back! so im not sure wat to do anymore....
MR2: 7A-GE
Old 02-05-2008, 07:16 PM   #9 (permalink)
Dude Wheres My Car?
nukem678's Avatar
Im going to hold out and see how long it lasts. The car only has 61000 miles on it.
