96 Dimmer Switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2008, 11:15 AM   #1 (permalink)
View livewire88's Photo Gallery
96 Dimmer Switch
Ok I have a 96 Camry LE. The headlights do not work on bright. Is this a common problem. Is it the dimmer switch or the headlight relay. It will switch to over on bright sometimes in a blue moon. It will burn on bright if you pull back on the headlight switch and hold it. I unplugged the relay the other day and plugged it back in and they worked one time, after returning to dim they would not come back on. I have tried to duplicate this again, no such luck.
Needing some help in GA.
livewire88 is offline   Reply With Quote
Old 02-06-2008, 11:47 AM   #2 (permalink)
There is a diagnostic procedure ... just a continuity check ... for the connector going to the dimmer switch. ... See the Body Electrical Section of the Gen 3 Repair Manual ...
starting on p. 24 ... see p. 29 for the switch test... Also note that there is a precaution about removing the yellow SRS connector from the harness.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 02-06-2008, 12:05 PM   #3 (permalink)
Where would i get this "manual" is it like a Haynes or Chilton, or Toyota.
Old 02-06-2008, 12:13 PM   #4 (permalink)
Not sure .... there has been a recent change regarding the online manuals ... some sort of legal infringement...
