Engine noise upon cold start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2008, 01:22 PM   #1 (permalink)
View tanglewood's Photo Gallery
Hello everyone. I have a 98 V4 and it makes an awful sound after I start it up. The racket continues while driving until the engine is warm. It occurs in any and all air temperatures (either 20 degrees or 100 degrees). It sounds like the AC compressor yet no AC or defrost is on. To me, it sounds like it is coming from the starter but I am not positive. Are there any thoughts about what it could be?
tanglewood is offline   Reply With Quote
Old 02-07-2008, 11:05 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The AC pulley turns even though the AC is off. Maybe something to do with the compressor clutch. Don't know what you mean by "sound" or "racket". A loud squeal is often a loose belt.
Kep
Old 02-07-2008, 11:12 AM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907127
iTrader Score: 59 reviews
Hard to tell...replaced the timing belt recently?...if not, could be the tensioner! I use to have a 96 5sfe (4cyl) in line, not V4...that made a lot of racket on startup, but quieten as it was driven...it was the TB tensioner
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 02-07-2008, 09:58 PM   #4 (permalink)
Thanks for the replies. I am not a car person so I didn't know I have an I4. The sound is just an incessant clanging. Its not a squeal from a belt ( I had a Saab that did that). Its not a ping or a tap. I don't know how to describe it properly. However, I will check out the tensioner and AC clutch and see if the condition resolves.
