'94 sedan wheel question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2008, 10:58 AM   #1 (permalink)
View XNavyflyer's Photo Gallery
I recently inherited a '94 4 cyl sedan with the stock 14 inch steel wheels. The tires are pretty much shot and I'm looking to replace them. Locally there is a set of 5 wheels and tires off a Solara (no year given). The tire size is 205-60-15. They are just outside the recommended 3% larger size but are quite a bit wider than the stock 195-70-14s. I was wondering if anyone else is using this set-up and if I could expect problems with rubbing. I'm a new guy here and will probably be spending alot of time till get the car the way I want it. Thanks in advance for any help .
XNavyflyer is offline   Reply With Quote
Old 02-07-2008, 11:07 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907127
iTrader Score: 59 reviews
Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
Welcome to TN! Use the above link....There's answers to questions, u haven't thought of yet!!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 02-07-2008, 12:03 PM   #3 (permalink)
I've looked through all the DIY stuff but I can only find info on tire diameter. The ones I'm looking at are slightly above the max recommended up-size of 3%. I'm more worried about the width. I seem to recall reading somewhere here that Solara tires will work on my car but, for the life of me, I can't find that post now. Anyone with any experience with Solara tires and wheels on a Gen 3 sedan?
Old 02-07-2008, 12:28 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
thoes wheels and tires will be fine. alot of camry models came with that exact size, msotly just the V6, but some 4cyl models as well. 15" wheels with 205/60/15s.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 02-07-2008, 12:42 PM   #5 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
I assume they are 1st gen Solara wheels.
Do you mean 205/60R16? That's the tire size that came with 16" Solara wheels like these. 205/60R15s would be almost right on in terms of diameter.
1st gen Solaras also came with 15s. Those came with 205/65R15 tires on these wheels
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 02-07-2008, 02:52 PM   #6 (permalink)
Tom. You are correct...I meant 205/60/16 and they are exactly like the first picture you posted. It looks like the general concensus is that they'll fit so I'll be picking up a set of 5 this weekend. Thanks to everyone for all your help.
Old 03-15-2008, 01:08 PM   #7 (permalink)
Unco's Avatar
View Unco's Photo Gallery
your speedo will be out by 3.79% if you went ahead with the swap. that's if the original tyre size you quoted is correct. the sticker on mine says 185/75 R14.
the tyres themselves won't rub, i don't think. i have 215's on one of mine. (17's)
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-15-2008, 02:11 PM   #8 (permalink)
Gameroom cash: $303055
The 94 4 cylinder cars did come with 195-70 R14's with H speed rated tires.
Mike
