Which year/engine do you have? How many miles on your car?
There was a post recently describing a partial/intermittent working power main relay...
Do your power windows work .... engine off?
Possibility that the PMR is the problem ... maybe tap it a few times, maybe get a replacement from the salvage yard to confirm that this is the problem...
One or two other possibilities...such as the Door Lock Control Relay ...
You might also check the 10A Gauge Fuse, and the 30A Power Fuse, but chances are they are ok...
A frequently mentioned problem with door locks has to do with related wires within the door hinge area breaking due to usage/vibration and fatigue...Though that may not be what is going on here.
Anything else that you might describe as part of the problem?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
