bad idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2008, 01:10 AM   #1 (permalink)
View sc3pt3r6uy562's Photo Gallery
3rd Generation bad idle
hi everybody, im new to the nation. i really need some answers about my gen 3 camry v6 le. my car has a bad idle after the car is warmed up. the rpm guage starts to drop down and go back up repeatedly shaking at the same time. but when its at high excelerating, it runs really smooth. it starts to act up when it comes to a stop or when i put it on park. can someone please help me with the problem? thank you for your time.
sc3pt3r6uy562 is offline   Reply With Quote
Old 02-15-2008, 02:40 AM   #2 (permalink)
Does your engine have a distributor? ...The description you give fits with burned distributor cap electrodes...If you have a distributor, try replacing the cap and rotor.
What is the condition of your plug wires ....ever been replaced? Sparkplugs lately?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 02-15-2008, 09:07 AM   #3 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Check your EGR valve... if it's clogged or stuck, the symptoms are what you have experienced.
BlueFusion6851 is offline   Reply With Quote
Old 02-15-2008, 11:51 AM   #4 (permalink)
ill try your guys advice today and ill work on it today. thank you guys.
Old 02-15-2008, 02:04 PM   #5 (permalink)
View Bear95's Photo Gallery
Is your engine light blinking or have you tried to pull the codes from the ECM?
Bear
Bear95 is offline   Reply With Quote
Old 02-15-2008, 02:38 PM   #6 (permalink)
my engine light never came on ever since i bought this car like ten years ago. so i guest that doesnt even work at all. lol.
Old 02-15-2008, 07:20 PM   #7 (permalink)
The EGR valve is the place to start.
Bear
Old 02-15-2008, 08:48 PM   #8 (permalink)
well i tried your guys advice and it did not work, but thank you so much for your advice. i wanted to try something else, so i called my friend with the same camry and i took off his maf sensor from his car and put it on mines and it turned out that the idle went really smooth. so what i think happend was when i went to get the smog done, that dumbass was messing with my maf sensor to make it pass smog. now i need to go get another maf sensor from the junkyard, and i also need to look for vaccume leak because the idle was a lil to low. thank you guys again for all your help.
Old 02-16-2008, 12:20 AM   #9 (permalink)
You might try cleaning the MAF ... If it is not actually broken .... think there is a heated wire element... Then it could be that some sort of dust or debris has somehow interfered with the air flow around the heated element...Not actually sure how the thing goes together though.
Old 02-16-2008, 06:53 PM   #10 (permalink)
3rd Generation
ive tried cleaning it, but still didnt work. so i went to get one at the junkyard today, and it only cost $100. put that thing on today and it ran perfect. thanks for everybody help again.
