Door locks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2008, 11:14 AM   #1 (permalink)
96LEWalt's Avatar
View 96LEWalt's Photo Gallery
Door locks
I have a 96 camry recently bought. The pass. door lock worked fine at first. But now I can not unlock the door with the key. I can lock the door fine. But the key will not turn enough in the unlock direction to open the lock.
Is this a common issue? Any thoughts?
Also any thoughts on a keyless remote/alarm install?
96LEWalt is offline   Reply With Quote
Old 02-16-2008, 11:28 AM   #2 (permalink)
Try graphite in the key opening...
There was a post recently ...somebody was going to install a wireless remote in a Gen 3...Not sure what kit or product he used though...It wouldn't be too difficult...just wire into the existing power lock controller.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 02-16-2008, 02:52 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If the graphite doesn't work (do both locks, it's good for them) how about other keys? If you have a key that has worn down it can do this. If you have a set of unused keys (always a good thing to keep for remaking keys later) and they work then get some new keys made up.
Kep
