Just moved to cali; need to pass smog test. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2008, 12:24 AM   #1 (permalink)
View Albuynp Ryeno's Photo Gallery
4th Generation Just moved to cali; need to pass smog test.
I got the car 1998 Toyota Camry from my local mechanic in Detroit. Now I now the car has been worked on a lot, its got an XLE tag when its really an LE and one of the o2 sensors is broken, which i am planning to replace. The car was built with the Calif. Emissions Requirement but idk if the catalytic converter is still working (its still there) or if other parts of the package are missing.
What should i look for and what kind of maintience should i do on my car before I got get it smog checked; besides fixing the o2 sensor, since i am already doing that.
Albuynp Ryeno is offline   Reply With Quote
Old 02-17-2008, 12:55 AM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
umm run seafoam on it to get rid of all other build up crap in the engine, and exhuast system...IMO but i really dont know much hope that helps
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 02-17-2008, 01:03 AM   #3 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
do the basic tune up if you havent already. then make sure you let the car warm properly by driving it a bit before taking it in.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 02-17-2008, 01:32 AM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Don't worry about the XLE badge. It's the V.I.N. and the mileage the smog shops will look at to run the test. 1st do a full tune up i.e. plugs, plug wires, oil, oil filter, air filter, PCV valve, new o2 sensors, and trans/differential fluid (both use ATF). If the exhaust is still original, you should be fine there. After you've done all of that, make sure your tires are at proper pressure, and drive the car for about 30min to warm it up then take it in for the test. The test center will usually give you a free retest if your car doesn't pass 1st time so you can fix whatever may not be right with the car. I would do a full tune up every other year(minus the o2 sensors), and stick to the basic tune up the rest of the time.
uibalnme is offline   Reply With Quote
Old 02-17-2008, 03:18 AM   #5 (permalink)
4th Generation
Their are 2 o2 sensors right? One before and one after the cat? So i need to replace them with cali o2 sensors right?
Old 02-17-2008, 03:32 AM   #6 (permalink)
Get a scan tool, or take it by an auto parts store to see if any DTC codes are stored in memory...even if the CEL light is not on. The oxygen sensors before and after the catalytic converter are supposed to detect a defective converter, and generate a diagnostic code.
Which engine I4 or V6? How many miles?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 02-17-2008, 02:35 PM   #7 (permalink)
I4 with 112,500 miles.
