If you look at p. 266 of the Gen 4 wiring diagram, you will see that the rear window defogger involves a timer, a light, and various other components. The problem is that it is not just an on/off switch. Apparently, the defogger is on only for a period of 15 minutes or so after you activate the switch. Maybe it would overheat and cause damage if it were left on continuously. ...So, to start the defogger from a remote starter, you would have to disassemble the defogger switch, and locate the correct terminal to connect to. Depending on whether the actual defogger activation switch is momentary, or a simple on/off activation, you might also have to install a relay of some type.
If you had a spare defogger switch from a salvage yard, you might be able to take it apart and see what is actually involved, before tearing up the one in your vehicle...just an idea. The difficulty here depends on what is involved in accessing the correct terminal within the switch. It would help if you could post a few pictures of the defogger switch.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
