Results after spark plugs and Throttle Body Cleaning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2008, 12:07 PM   #1 (permalink)
stockmover's Avatar
View stockmover's Photo Gallery
In a previous post I had wrote about a slight whining sound I was hearing from the left side of the engine since I installed spark plugs, fuel filter and PCV Valve. Its a V6 so I had to remove the intake manifold to get to the rear 3 plugs.
Today I did a throttle body cleaning based on the DIY post here. Came out pretty well I must say. It was fairly dirty. I noticed the car started up much easier. The RPMs were high(1,800) for a second, but I did have the hood up and its about 30 degrees out right now. After I closed the hood and about 3 minutes later it was down to 1000 RPMs.
Question: Does anyone think I need to change my wires since I did my spark plugs? Could that have caused the whining sound I am hearing now, occasionally it sounds like its trying to cut off. Like a loss of power sound almost. Anything other suggestions?
Thanks,
Stockmover
stockmover is offline   Reply With Quote
Old 02-18-2008, 12:43 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Whining sound seems more like a loose fan belt to me but I don't know of any on the driverside. If it could be a whistle then maybe you dislodged a vacuum line. There are several.
I can't see spark plug wires resulting in a whine. However, you can check their resistance and determine if they need to be replaced. Check the distributor cap center post (if you have one) as well. I believe 20,000 ohms resistance is the max acceptable.
Kep
Old 02-18-2008, 01:34 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Originally Posted by Kep View Post
Whining sound seems more like a loose fan belt to me but I don't know of any on the driverside. ....
Our cars dont have any fan belts at all...so that cant be the problem.
Nothing on the drivers side except for transmission, vacuum lines, and distributor. Could be the distributor making some noise. I had a Honda Accord 92 model that the distributor went out on and it made a whining sound before it died.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 02-19-2008, 12:19 PM   #4 (permalink)
stockmover's Avatar
Red face
Thanks again for the opinions. I called the local Toyota dealership today and they said it would be around $92 to run a diagnostic to tell me the problem. I really do not want to take it there but the check engine light is irritating.
It's cold out today but I will try to let it run then mess with some of the vacuum lines to see if I hear any difference. I might get lucky and find something there before taking it in.
Old 02-19-2008, 12:54 PM   #5 (permalink)
Sometimes it is difficult to get the intake manifold gaskets to seal correctly...You might take a can of starting fluid, and carefully put a few sprays around the intake manifold ... listen to see if there is any difference in RPMs...
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 02-19-2008, 12:58 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Does auto zone or Murrays read CEL codes for free still?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-20-2008, 12:54 PM   #7 (permalink)
stockmover's Avatar
I am not sure. I took the car to Sears and Autozone, they both claimed they cannot read any codes and do not have the proper equipment to find out what the check engine light means. I think I am getting the run around but who knows.
Old 02-20-2008, 01:58 PM   #8 (permalink)
stockmover's Avatar
Another picture, advice?
I hope I did this correct but I sprayed a little starting fluid near the throttle body while the engine was idle. I noticed a change in the sound of idle immediately. The RPMs moved up some then went back down to 1000.
Here is the picture of where I sprayed. Does this tell me anything? It has to be an air leak somewhere, since the check engine light only came on after I installed the spark plugs and had to remove the intake manifold.
http://www.box.net/shared/static/2363sqrs4g.jpg
Thanks,
Stockmover
Old 02-20-2008, 03:04 PM   #9 (permalink)
Autozone will read the codes for free. Go to a different one or get someone else at that store that wont give you the run around.
Old 02-20-2008, 03:27 PM   #10 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
^ yah the read mine and i just came home and look it up here and found the answer so i was good
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 02-20-2008, 04:24 PM   #11 (permalink)
View marc780's Photo Gallery
No.
Try a different hose clamp. Once you take the old clamp off, remove the big hose and inspect it, and the sealing surface on the TB for dirt and the hose for holes. Tighten the heck out of the new hose clamp and test again.
When i did the plugs on my V6 it was like minor torture because i did not want to remove the plenum as you did - i just worked behind the plenum to get the plugs out. It was difficult and frustrating but i managed to do it.
having done car work like this many times before - I did not remove my plenum because i did not want to risk a vacuum leak removing an intake piece just to change the plugs - maybe the new gaskets you put on are not sealing right and need to be redone
Old 02-21-2008, 03:01 AM   #12 (permalink)
stockmover's Avatar
I will try the new hose clamps to see if that is the problem. It's irritating because I know its something minor and overlooked. I will also try another Autozone or Advance Auto to see if they can tell me what the code is. I will keep everyone updated.
Thanks,
Stockmover
Originally Posted by marc780 View Post
No.
Old 02-21-2008, 03:42 AM   #13 (permalink)
OldSchool Yota Enthusiast
ROBS's Avatar
View ROBS's Photo Gallery
I second the hose clamp, but if that doesn't solve the noise, I would also try the starting fluid thing near the intake where you took it off. Spray it all around. Did you re-seal it like I suggested in the other thread? A new gasket is only like $5 or less for a cheap one at any old parts store. Even if you get a fel-pro and use the black form-a-gasket instead of OEM, its a lot better than the old one you re-used.
1975 Toyota Celica GT - RA22 - 22-R (Project)
1975 Toyota Corolla - TE31 - 2-TC (Project and Weekend Cruiser)
1988 Toyota Camry LE - SV21 - 3S-FE (Wrecked and For Sale or Parts)
1993 Toyota Camry LE - VZV?? - 3VZ-FE (Daily driver)
ROBS is offline   Reply With Quote
Old 02-21-2008, 09:22 AM   #14 (permalink)
stockmover's Avatar
Are you talking about the gasket for the throttle body? I checked autozone online for all of the gaskets and I do not see one for $5, I do see a throtte body gasket for $15. Is this the one you are talking about? I meant to ask you that on the previous thread.
I plan to work on it Sunday.
Thanks.
Old 02-21-2008, 09:58 AM   #15 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
The clamp on your air filter box (left of the maf) appears to be unlocked. Perhaps box isn't sealed and sucking air through the crack.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
