2000 4-cyl losing oil. Where? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2008, 10:01 PM   #1 (permalink)
View davj3368's Photo Gallery
I replaced the valve cover gasket hoping that the oil was leaking out there. Nope...stiill losing oil. Cleaned engine with cleaner, pulled tire, fired up engine and watched. All I can see is a small, steady drain of oil from the area of the oil pump. Is this a common place to have something fail? Seals? Gasket? I don't want to go through the hassle of replacing the oil pump (pulling pulleys, belts, etc) if that isn't what's wrong.
Also, is it necessary to pull the oil pan when I replace the oil pump?
I'm pure shade tree mechanic, and don't mind attempting this, but I don't have unlimited selection of tools. :-) Is it something best left for a certified mechanic?
Ideas?
Dave
davj3368 is offline   Reply With Quote
Old 02-20-2008, 06:21 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
That's a clue. Will probably be the oil pump shaft seal and/or oil pump body o-ring. When was the last time you replaced the timing belt?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 02-20-2008, 07:21 AM   #3 (permalink)
I replaced the water pump and timing belt about a year and a half ago.
Why?
DJ
Old 02-20-2008, 08:01 AM   #4 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
Why?
DJ
if indeed oil pump shaft seal and/or oil pumo oring seal leaking, (only a $7 or $10 in part)you have to remove the timing belt in order to access the oil pump.
my 97 camry 4cyl was leaking at the oil pump o-ring, i did the timing belt 3 times within a month.
1st time just to change timing belt, oil pump seal, cam seal, crank shaft seal water pump
2nd time found oil pan area wet, and oil dripped on garage floor, then i used red gasket silicone from walmart patch the oil pump o-ring, the old rubber was dried up and in pieces
3rd time was when i finally bought the real oem new oil pump o ring.
bronzemaxell is offline   Reply With Quote
Old 02-20-2008, 11:13 AM   #5 (permalink)
I replaced the water pump and timing belt about a year and a half ago.Why?
Because whomever did it should have replaced those low cost seals (as bronzemaxell points out) while they were in there. If a shop did the job you might want to review your bill to see if these seals are on the list of parts.
Old 02-20-2008, 11:19 AM   #6 (permalink)
Oh. Actually, my Camry broke down on me (water pump) while I was on a road trip a year or two ago. We had to leave it with a shop, rent a car, and come back a few days later to get it. I'm sure I still have the receipt, and I remember that they installed new belts while they were in it, but I doubt they pulled the oil pump.
Anyway, looks like I'll be pulling the pump this weekend and inspecting the o-ring and seals. I'll report back after I perform the work!
