help me stalls out in drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2008, 10:57 PM   #1 (permalink)
View getyourgunn's Photo Gallery
3rd Generation help me stalls out in drive
i have a 1993 toyota camry le 2.2 liter with about 120,000 miles and it has been running fine but just stalled out on the way home at a stop sign. i managed to start it again but dies if i dont keep it rev-ed, but then if i try to put it in drive it dies immediately.
getyourgunn is offline   Reply With Quote
Old 02-20-2008, 01:42 AM   #2 (permalink)
Not sure, but check your distributor cap ...the interior electrodes should be bright and shiny. If you find any oxide coating, replace cap and rotor. Sometimes the ignition coil can cause problems. Have you replaced your sparkplugs or plug wires lately?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 02-20-2008, 06:15 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Usual suspects; IAC, EGR (vacuum leak), other vacuum leak.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 04-13-2008, 10:54 PM   #4 (permalink)
at it again
well i finally took it to the shop and they replaced the distributer spark plugs and wires and it worked well for about six weeks but is now doing the same exact thing. also could anyone tell me where the idle air control valve is located?
Old 04-13-2008, 11:02 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
it is located under your throttlebody- it's a unit that's screwed on to the bottom
HaHa
Old 04-13-2008, 11:21 PM   #6 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I had a similar problem about a year ago. It was the ignition coil. Only $35 at Advance Auto Parts. I highly recommend changing the coil.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
