93 camry radiator smoke!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2008, 03:44 PM   #1 (permalink)
View redace666's Photo Gallery
im getting smoke right around my radiator cap and im not sure whether its the cap or the radiator itself , but its smoking a bit and its annoying, any helps would be appreciated, thank you!
redace666 is offline   Reply With Quote
Old 02-20-2008, 04:16 PM   #2 (permalink)
View marc780's Photo Gallery
I'd start with the easy and cheap answer first, replace the radiator cap. Maybe the cap has a broken or weak spring, or the seal is worn out, so just change it.
Is the engine overheating? Are you losing coolant? Is there any coolant in the oil? You didnt mention any other symptom except smoke so maybe your head gasket is not blown and all you need is the cap.
Old 02-20-2008, 05:46 PM   #3 (permalink)
you were right it is just the cap, because i took it to my mechanic and he said my rad was fine the seal on the cap was worn he fixed it in 10 seconds and i was on my way! thanks for your help!
