I am assuming a pre primed metal surface. this method will be done in about a week, I prefer alot of drying/curing time before I put the part on the car.
You will need a clean area, plastic drop sheet the area around your work... not really for dust, but more for over-spray. I use cardboard like a large oven cardboard box. paint the inside first, you can use it for practice.
Get an organic vapour filter mask, half mask is usually fine.
Wash with vinegar and water dry with acetone or lacquer thinner and lint free cloth, then spray a mist of paint 10 inches above and see how that works. let it dry according to the re coat times.
Do same for outside, you may want to let it dry first, wet sand and wash before base colour re coat this time. Do not wet sand and wash befor clear coat or else you lose the metallic flake effect.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
