P0401 code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2008, 06:59 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
P0401 code
1996 Toyota Camry (4cyl)
My brothers car had a check engine light, so we took the car to autozone to pull the codes, there was a P0401 code,
What does that code mean and how do I fix it? Thanks
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 02-21-2008, 07:06 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
That's a code that often comes up. Please use the search function next time before posting a new thread.
That said, here are a few threads about the subject:
Check Engine Light P0401, P0402, P0440
Egr 0401 Light Went Out
P0401 EGR woes.........
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 02-21-2008, 10:27 PM   #3 (permalink)
View digmycelica's Photo Gallery
USA
I'm going to tell you how to fix it without reading 100 post.
First crank the engine , pull off the vacuum hose on the EGR valve. Stick a spare vacuum hose on the EGR valve. and suck on it to see if the engine dies or stumbles. If it does, then you know the EGR valve is good and the port is not clogged. Now, the next step is to replace the modulator valve (this is the valve that feeds the vacuum to the EGR valve.) and it has 3 ports on it and 1 on the bottom. Then replace the electric vacuum valve that is located on the back side of the engine near the oil pressure switch. it is held in place with 1 bolt and has 1 electrical connector plus 2 vacuum hoses. This will correct your 401 code problem.
digmycelica is offline   Reply With Quote
