gen 3.0 and 3.5 difference - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2008, 12:00 AM   #1 (permalink)
View psyanyde's Photo Gallery
3rd Generation gen 3.0 and 3.5 difference
Alright, I know this is a noob question but I have to know.
what's the difference between a gen 3 and gen 3.5?
i have a 93 camry v6.. is mine a gen 3 or a gen 3.5?
help?
1993 Camry V6 LE 4 Dr - 236K as of Feb 2008. All Stock.
psyanyde is offline   Reply With Quote
Old 02-24-2008, 12:04 AM   #2 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
92-94 gen 3
95-96 gen 3.5
minor differences between the two..
headlights/bumper lights
rear panel
obdI/obdII
etc...
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is online now   Reply With Quote
Old 02-24-2008, 12:06 AM   #3 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
The 93 v6 already had obd2. The 4 cylinders didn't get obd2 until gen 3.5 (1995) I believe.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 02-24-2008, 12:09 AM   #4 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I believe that the 93 is still the 3VZ-FE which is OBD-I. I don't think the 1MZ-FE (OBD-II) was introduced until 1994. The 5S-FE didn't get OBD-II until 1996
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 02-24-2008, 12:10 AM   #5 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
I believe this is accurate.
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 02-24-2008, 04:41 AM   #6 (permalink)
3rd Generation
ok
all this 1MZ-FE OBD stuff's all chinese to me
can someone please take the time to explain them to me?
what they mean
what they're for?
I'm new to all this, as i'm sure you can tell.
thanks
Old 02-24-2008, 09:14 AM   #7 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
OnBoardDiagnostics
It's where a service shop can hook into the car to find error codes as to what is causing the problems. They can only read OBD-II.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 02-24-2008, 11:34 AM   #8 (permalink)
'95 Camry 5S-FE
Originally Posted by psyanyde View Post
ok
what they mean
what they're for?
thanks
You have the 3VZ-FE which is the engine code for your car. It is OBD-I which means that the computer is not as sophisticated and you can't use a scan tool on it. If you want to pull a code from your computer you use a wire to jump the terminals TE1 and E1 on the diagnostics port under your hood then turn your key to the on position and count how many times the check engine light flashes. You then look it up on a a chart. The 1MZ-FE is the engine that was used from 94-96 and that is OBD-II which means that a scan tool is required to check codes and the computer is more sophisticated.
