1999 Camry Vibrating tach needle on idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-29-2008, 12:44 PM   #1 (permalink)
View steppinthrax's Photo Gallery
I have a 99 Camry with about 34K on it. I've had it about a year now. I've done some minor engine work on it. I replaced the plugs to BOSCH double pt tips and replaced the ignition wire set. I noticed some improvement in idle and engine noise. But one thing I'm getting is on idle I get a vibrating tach needle. The engine overall sounds good with no weird sounds. I'm not quite sure if you guys notice your tach needle jitters a bit on idle. I'm at lost on where to look......
How do I check motor mounts. I can see the dogbone one on the top and the one right in front of the exhaust manifold but that's about it....
steppinthrax is offline   Reply With Quote
