Parking Lights & Hazard Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-29-2008, 01:30 PM   #1 (permalink)
View vertigo14k's Photo Gallery
4th Generation Parking Lights & Hazard Lights
Hi I recently installed some L.E.D lights on my turning signal lights, Mostly everything is working exept for the parking lights when I turn everything on. N my Hazard Lights won't come on.
vertigo14k is offline   Reply With Quote
Old 02-29-2008, 01:57 PM   #2 (permalink)
I would also like to add that my turning signals, front lights, and rear lights all work.
Old 02-29-2008, 02:43 PM   #3 (permalink)
ELL
ELL's Avatar
View ELL's Photo Gallery
This may sound obvious, but did you check your fuse for the hazard lights?
When working with lights, such as the dome light, it is pretty common to blow a fuse.
just an idea
2000 Camry LE I4.
ELL is offline   Reply With Quote
Old 02-29-2008, 02:46 PM   #4 (permalink)
4th Generation
Sorry I forgot to mentioned that I have replaced 3 fuses for the hazard 10A, and everytime I try my hazards after I have replaced the fuse it burns out.
Old 02-29-2008, 04:14 PM   #5 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
what wattage are these leds, sounds like your pulling to much power and its blowing the fuse.
Might want to try a 15amp fuse
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 02-29-2008, 05:17 PM   #6 (permalink)
ELL
ELL's Avatar
LEDs don't typically pull too much power unless you have a whole lot of them
for instance, I have dozens of leds attached to a 3 amp fuse, and they only draw about 1.5 or 2A worth.
I wouldn't increase the fuse size...they're there to keep wires from melting and potential fires
sounds like he has a short somewhere.
maybe your grounds aren't connected properly?
How are your leds wired?
2000 Camry LE I4.
Old 02-29-2008, 05:30 PM   #7 (permalink)
Go camry goooooo
DrewsCam's Avatar
either way there is something wrong in the wiring, like ELL said check your grounds
Old 02-29-2008, 07:35 PM   #8 (permalink)
4th Generation
The L.E.D's that I have replaced my stock 12 volts corner lights, and the L.E.D's are 12 volts also. they are work when I hit the turn signal switch, but they won't come on when I have my low beam or hi beam lights on how they are suppose to come on, but they will work, when i'm turning. Don't know if it has something to do with my Hazards. The Hazards won't come on at all, and all this happened when I installed the L.E.D's, I would also like to mention that I've replaced my hazard fuse twice it burns out all the time when I hit my Hazard Switch
