Transmission Service - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2008, 08:13 PM   #1 (permalink)
View wcarlton's Photo Gallery
3rd Generation Transmission Service
I just got a 96 Camry from someone in my family and I was wondering if it is a Drain and fill type tranny or is there a gasket and filter that needs to be replaced???
thanks for any help you can give
wcarlton is offline   Reply With Quote
Old 03-05-2008, 02:36 AM   #2 (permalink)
View Camry-rulez's Photo Gallery
there is a filter and a gasket. I must drain the the fluid , change the filter and than add new fluid... simple
Euro CAMRY. 3.0 GX V6 (auto.) 1993'
Toyota Camry and Peugeot 205 Driver
Camry-rulez is offline   Reply With Quote
Old 03-05-2008, 10:38 AM   #3 (permalink)
Dave's
View Dave's's Photo Gallery
Think Toyota says the filter doesn't need to be changed. You can drain and fill or you can remove the pan and clean or replace the filter. If you remove the pan, you'll probably want a new gasket. Mine came with the filter for about $25 at a parts store.
Dave's is offline   Reply With Quote
Old 03-05-2008, 02:51 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Draining the pan will get about 2 quarts out. I believe my 95 I-4 holds about 5.5 quarts so you need to drain & refill about 4 times to get mostly new fluid in. I try to do it at every other oil fill and figure that way I change all the fluid about every 30,000 miles. I change (or clean) the filter at 100,000 intervals. My differential is supposed to hold about 1.5 quarts. I refill that every 30,000 miles. (It's a good idea to make sure that the fill plug unscrews before you drain the differential.) I do not believe in power flushing the transmission.
Kep
