Gen 4 Rim Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2008, 01:06 PM   #1 (permalink)
datnguyen24's Avatar
View datnguyen24's Photo Gallery
4th Generation Gen 4 Rim Question
I have a gen 4 and was wondering if the Konig Prophet 18x7.5 would fit? I found a deal on some but wasn't sure if they would fit. If anyone knows please help.
datnguyen24 is offline   Reply With Quote
Old 03-06-2008, 01:25 PM   #2 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Depends on the bolt pattern and the offset. You need a 5X114.3 bolt pattern, and somewhere in the vicinity of a 40mm offset.
eddie926 is offline   Reply With Quote
Old 03-13-2008, 06:25 PM   #3 (permalink)
View George84's Photo Gallery
Thats nice to know, I did not know the bolt pattern was the same as the rx7 pattern. I have a few extra sets of wheels for my rx7 and now I know I can put one set on my gen 4 camry, hell I might put a set on my gen 3 camry too.
~George
2000 Toyota Camry LE 2.2L S5-FE I4
George84 is offline   Reply With Quote
Old 03-13-2008, 11:09 PM   #4 (permalink)
Does anyone know what the offset and how wide the stock wheels are? I know my car (2000 camry) came with 205/65 R15 size tires, I want to put on a old set of 15" BBS wheels I have with a 40mm offset and 225/60 R15 tires. Just wanted to see if anyone else is running a 225 and what the stock wheel offset is.
~George
Old 03-14-2008, 07:54 AM   #5 (permalink)
'95 Camry V6 XLE
Can't tell you the stock offset and width, but you shouldn't have any problems with a 15" BBS with offset of 40mm. The BBS is probably 6.5" wide. The 225/60 tire will be fine.
If you've never used this calculator before you can plug in your current specs, then compare to potential new specs and get an idea what the effects will be on your speedo, and clearance with your suspension, etc.
http://www.rims-n-tires.com/rt_specs.jsp
