2000 Camry tail light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2008, 07:16 PM   #1 (permalink)
View mail2mz's Photo Gallery
Hi All,
The tail light of both sides do NOT light up at evening. The brake lights are OK. And the head lights will be automatic on at evening. Any idea on this issue?
Thanks,
Mike
mail2mz is offline   Reply With Quote
Old 03-07-2008, 07:31 PM   #2 (permalink)
ELL
ELL's Avatar
View ELL's Photo Gallery
Have you checked your fuses for that particular circuit?
I'd start there. Then check the bulbs (even though it's probably not because they're both out)
2000 Camry LE I4.
ELL is offline   Reply With Quote
Old 03-08-2008, 12:46 AM   #3 (permalink)
View CarDrivinHick's Photo Gallery
Yes, definitely check fuses, then, if that doesn't work, I hate to say this, you may have to check (or get checked out) the wiring, that's the only other option.
CarDrivinHick is offline   Reply With Quote
Old 03-08-2008, 12:33 PM   #4 (permalink)
Gameroom cash: $303055
Check the loom of wires inside the trunk, by the driver's side trunk hinge. Open up that loom and look for frayed or broken wires. Repair as necessary. That loom is exposed to constant flexing as the trunk is constantly opened and closed. Eventually, some of the wires inside that loom break. I would note the color of the wire(s) for the back lights, by looking near the bulb socket. Pay particular attention to that color wire inside the loom.
Mike
