odd thing i noticed today on my fuel gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2008, 10:43 PM   #1 (permalink)
View saoxcore's Photo Gallery
i was at a stoplight and it went down. all the way to the little gas picture. and then slowly, and i mean slowly it started to move up as i was driving.
first time ive seen this happen (ive only driven it about 100 miles tops though..just got it)
anyone know why this happened? is this a problem?
saoxcore is offline   Reply With Quote
Old 03-07-2008, 10:45 PM   #2 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
it might be from your fuel level sending unit.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 03-07-2008, 10:50 PM   #3 (permalink)
care to explain lol
btw its a 95 camry xle v6
Old 03-07-2008, 11:21 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
sounds like that. if that unit goes bad, ull read incorrect fuel level. somthin ya might want to get fixed.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-08-2008, 12:16 AM   #5 (permalink)
bout how much would it cost a mechanic to fix it?
Old 03-08-2008, 12:42 AM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Sounds like the level sender float is sticking, and when you go to stop, the gas in the tank sloshes around enough to bring the sender float down pretty low. How much gas is in the tank?
I know that when I go up/down steep hills or in and out of my work's parking garage, my fuel gauge goes down a bit (sometimes 1/4 of a tank) then slowly comes back to where it was when I was driving level.
I don't know if the sender is attached to the fuel pump assembly, but on some cars it is, and would be as simple as removing the fuel pump by removing the rear seat and the cover is very visible.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-08-2008, 01:08 AM   #7 (permalink)
well the tank is half full, and it went ALL the way down. like past the empty line. and its never done this before in the little time ive had it. i was on a pretty level ground btw. but its only done this once i dont really think its much of an issue (i hope)
Old 03-08-2008, 04:14 AM   #8 (permalink)
Black95Cam's Avatar
correct.
its located on top of the gas tank. remove the rear bottom portion of the seat then you should be able to see it.
Old 03-08-2008, 11:07 AM   #9 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
This is the fuel pump and sending module from a 1995 I-4 Camry. The top is to the left.
I believe the square black looking thing on the right is the float. As it goes up and down I believe it turns a rod which is "read" by a sensor and a resistance value is sent to the gauge or ECM to display the level. There could be a mechanical problem or a wiring problem.
Kep
