Exhaust System Fix - You Decide - $2400 or $3.47 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2008, 08:44 AM   #1 (permalink)
Ironsidesusa's Avatar
View Ironsidesusa's Photo Gallery
Hi Folks!
Last October when the wifey and I drove our "new" Camry down to our Florida home, it developed a problem with the exhaust system. I guess all that high speed driving down to our winter home in Florida took it's toll on my vintage 1997 Toyota. By the time I got to Wesley Chapel, it really started to sound very loud.
And so I decided it had to go in the shop for a looksy just to find out what the heck the problem might be. The local Toyota Dealership experts in town told me the bad news. After examining the vehicle on their lift, they took me into the shop and showed me the problem. Bottom line -the whole exhaust system in my ten year old car had to be replaced and it would cost me $2400 to make it right. And so I went home to cry in my beer and think about it a little before I took action to get the thing fixed.
Back at the house, with the engine running, I jacked up the car and crawled under my honey for another look. "Hey wait a minute!" I said. "This exhaust system doesn't seem to be in bad shape at all!" Except for a tired gasket between a bolted flange pipe connection (right after the catalytic converter), the system didn't seem to be in need of complete replacement!
I figured there must be a cheaper way to fix this problem other than brainlessly forking over $2400 to the local Toyota dealership. I figured their fix was equivalent to replacing the engine when all it might need were new plugs and wires. Oh yea, the problem would be fixed for sure but I would have to sell shoes for another five years to pay the bill I had generated on this!
My solution: I applied HiTemp RTV you can get at WALMART's automotive Dept. to the gap where the tired gasket was located between the two bolted flanges.
The net result of the fix was I was out $3.47 rather than $2400.
The fix might not look pretty but my wallet thanked me for it! You know the red sort of grows on you after while.
By the way, I have now driven my quiet 1997 Camry over 500 miles and she is still purring like a kitten. Also, I now have exactly the same fix on my son's 1998 Toyota Camry up North - now another purring kitten.
Ironsidesusa (a.k.a "Al")
P.S. My Dodge is up North and she is still going strong! I am a firm believer in the philosophy "Make It Last"
Ironsidesusa is offline   Reply With Quote
Old 03-08-2008, 09:07 AM   #2 (permalink)
View xm camry's Photo Gallery
Hey if it last then power to you, $2400 is a shitload of money I would have gone to my local shop and they probably would have charged me $60 to weld it, $3.47 still cheaper :P
'94 Camry LE sedan 4 cyl.
1st car hand me down :P
xm camry is offline   Reply With Quote
Old 03-08-2008, 10:07 AM   #3 (permalink)
ELL
ELL's Avatar
View ELL's Photo Gallery
Well xet, they wanted to replace his entire system, not just weld it
Anyway, good read!
2000 Camry LE I4.
ELL is offline   Reply With Quote
Old 03-08-2008, 12:10 PM   #4 (permalink)
Fall Back Positions
I still have several fall back positions if this turns out not to fix the problem in the long term. They are - in order of decreasing preference (and increasing price) after the HiTemp RTV approach:
1. Cut the bolts that hold the flange joint together, install a new gasket and re-bolt with new bolts. The old bolts are just too corroded to successfully take apart.
2. Cut the exhaust piping on either side of the flanged joint and using bolt clamps, a section of new exhaust piping and pipe couplers etc. re-assemble.
3. Go to a reputable mechanic (I know one up North but most are either rippoff artists or hacker mechanics) and have them weld the flange joint together. (I was aware of the fix that has been posted here but at this point I am too dam cheaper to go to the added trouble.)
Thanks for the inputs.
Old 07-06-2008, 03:47 AM   #5 (permalink)
Latest Update On "The WAMART RTV Exhaust Fix"
Hi All!
Just a quick note to let you know that recently I used exactly the same fix approach on my son's 1998 Camry up North. (Before "the fix" his car was really loud. After "the fix", it passed the Massachusetts Vehicle Inspection with flying colors) Both cars are still running fine. Net savings for the family is now at $4800 less the $3.47 cost for the WALMART RTV.
Old 07-06-2008, 10:54 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
This is the option I used. An angle grinder with thin metal cutting wheel works slick. I actually took the entire system off in one piece to do this as I was not sure I could get access while in place to clean off the rust. I also discovered that the spacing of the two flanges was a little too far apart to seal the replacement gasket so I just used two gaskets and longer bolts. Shops like to cut and weld a slip joint on but welding on the top side is tight for proper access as well.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-06-2008, 11:15 AM   #7 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
I did the exact same thing on my car. There was a leaking gasket too, what I did is loosen up the bolts so I could easily scrape the old gasket out. I squeezed a copious amount of this stuff and basically made a new gasket with it, then retorked the bolts, added some more around the area, final torquing, and no more noise. Great stuff.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 07-06-2008, 10:26 PM   #8 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
nice
HaHa
Old 07-08-2008, 10:11 AM   #9 (permalink)
Heat's Avatar
View Heat's Photo Gallery
I had a similar problem in an old Volvo of mine after I replaced the exhaust system cat back, I ended up having a place weld the cat to the down-pipe.
But yeah, $3.47 is cheaper. Was that before or after tax?
Heat is offline   Reply With Quote
Old 07-08-2008, 01:12 PM   #10 (permalink)
xet
View xet's Photo Gallery
Thumbs up
Anyway, good read!
haha i didnt say that :P
but to the op, congrats on the fix and nice job not just shelling out the money to the stealership
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 07-08-2008, 02:11 PM   #11 (permalink)
View AdamS's Photo Gallery
Good ol' Clark Howard approach...although I would consider this a temporary/band-aid fix. It might be best to change the gasket and bolts as suggested earlier (a slightly more expensive solution). I would be interested to see how long this holds up.
-=AdamS
1992 3VZ-FE with 218K
Check her out
AdamS is offline   Reply With Quote
Old 07-08-2008, 07:28 PM   #12 (permalink)
groovemasterodi's Avatar
View groovemasterodi's Photo Gallery
What part of the metro ATL area does this Camry prowl, it looks familiar for some reason
2001 Camry..5FSE..
groovemasterodi is offline   Reply With Quote
Old 07-09-2008, 07:28 AM   #13 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i would recommend option 1 like still running said if it starts leaking again. im always leary on using silicone on exhaust components even if ifs high temp.
Old 07-09-2008, 09:10 AM   #14 (permalink)
I know this is totally off topic but.....Formerly in Snellville now in Decatur...However, I'll say that my car looks pretty different now...running my stock wheels, invader hood, etc etc....desperately need to get a nice lightweight set of wheels...I am selling the IS300 wheels to go for a different look...
-=Adam
Check her out
Old 07-09-2008, 07:40 PM   #15 (permalink)
snellville is where i recall seeing it, been awhile but ya. Small world if it indeed was
2001 Camry..5FSE..
