Hi all,
My dilemma at this time is I am getting the single-click won't start (but sometimes will start with no problem) problem on my 94 Camry.
I realize there is a great likelihood that my problem is the starter solenoid.
My question is regarding those two cables on the side. I see one with a round connection and a nut on it. Is that the positive cable that goes to the battery? I asked my mechanic to give me new battery cables, and he gave me new connectors at the battery. I guess it's not as simple as "the positive cable goes to the starter" because it's all wrapped up within the harness and splits off to other components. But what if I wanted to change that out?
What is the other wire? It's got a rectangular clip on it. I have a pdf of that section of the wiring diagram but it's not clear.
One replacement starter I have seen shows this rectangularly-terminated wire looping back to one of the through-bolts on the starter itself.
That's not how my car has it.
(Here's a pic:
http://www.partsamerica.com/product_.../17143_ang.jpg )
So what I wanted to do before shelling out $150 for a starter is to see if I have bad contacts there.
How do I "jump" the starter to the ignition?
If I just leave the ignition switch in the "on" position, do I then jump that larger cable to the positive terminal on the battery?
The battery is new and tested good, 14 volts.
Thanks a lot!!!
l
