Car will not start ...a few codes .. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2008, 10:30 AM   #1 (permalink)
View kongeee's Photo Gallery
Exclamation Car will not start ...a few codes ..
Hi everyone.
during the last 2 weeks i have starting problems. sometimes it would start and run fine and sometimes it would not start. when it doesnt start, i just come back in a bit and try again then it works.
here are the codes that i got:
P0340 - Camshaft position sensor A - Bank 1 Circuit Malfunction
P0401 - EGR Flow Insufficient
P0773 - Shift Solenoid E. Circuit Eletrical
any help in fixing this would be nice.
I need to know what to buy, diagnose and how to fix it.
Thanks everybody.
kongeee is offline   Reply With Quote
Old 03-09-2008, 12:36 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
the two last codes are no worry, as they won't prevent your car from starting
get the first code fixed. it sounds like the camshaft position sensor is done for.
When it says bank one, it means the front bank (which is actually the one close to he firewall)
I know where the crankshaft sensor is on the rear bank, but I'm not sure on the front bank...that, and it'd be a bitch to get to for sure. You can either go to your local dealership and get a price on a camshaft position sensor and ask them where it is and change it yourself, or you can take it to a shop to have it dealt with ....I would recommend T-Lex since you're toronto.
HaHa
Old 03-09-2008, 02:32 PM   #3 (permalink)
do u have the number for T-Lex and where is he located?
o ya..i have a 95 camry v6.
any idea how much would it cost?
Old 03-09-2008, 02:52 PM   #4 (permalink)
TN Pussy Man
http://www.toyotanation.com/t-lex/
He's at woodbine and 16th
Basil is a great guy. I don't like ppl touching my car, but when I need something done that I can't do myself, I take it to him.
as for cost...I don't see it being too much for labor hopefully...the sensor though...that's what might cost you. just give him a call and tell him the code and then he'll have suggestions for you and usually a general price. more often than not though, he'll ask you to bring your car in to have a look and then he'll tell you what needs to be done.
HaHa
Old 03-09-2008, 08:34 PM   #5 (permalink)
i found out where the camshaft sensor was and took it out and cleaned it. there was so much oil sludge on it.
after cleaning it, the car started.
i just i ll run it for the next week and see what happens. if it works fine then i guess i wont change the sensor.
Old 03-09-2008, 09:30 PM   #6 (permalink)
TN Pussy Man
good stuff
was it in the same location on the rear as on the front?
as for the oil sludge....if there's enough to gunk up the sensor...you may want to take your valve covers off to get a look at the buildup in your engine, as that's not a good sign...
HaHa
Old 03-10-2008, 08:00 AM   #7 (permalink)
good stuff
i didnt check the rear cause it said bank 1 so i only did the front plus i dont where the rear is located.
if i do take the valve covers off and see a lot of sludge. what can i do? do i just take it off to look at it and put it back?
Old 03-10-2008, 12:04 PM   #8 (permalink)
TN Pussy Man
lol...well...you see....bank one is actually the bank that's by the firewall....the one on the front is actually technically the rear bank....
but yeah, the cam sensor on the front of the car is easy to deal with. I guess you got lucky and the code just kinda went away by itself then.
As for what to do if you do see sludge? Clean it up as best as you can while the valve cover's off. Then run a bottle of seafoam through your engine oil, dump, run, dump and it should get a decent bit of the sludge out
HaHa
Old 03-16-2008, 11:14 AM   #9 (permalink)
dammit..the car didnt start today..i check the code and its the crankshaft position sensor bank 1. how do i access bank1 ? any pics?
Old 03-16-2008, 12:18 PM   #10 (permalink)
NBBADTOYS
View keisuke's Photo Gallery
its buried in the bowels of the motor in the rear beneath the plenum if you want to try it you will need to mount the motor and reach down best to tow it to T-lex
1997 Toyota Camry XLE V6- 308500 and counting
keisuke is offline   Reply With Quote
Old 03-16-2008, 12:28 PM   #11 (permalink)
who should i ask for at T-lex?
i think i ll call him tomorrow then tow it.
Old 03-16-2008, 02:22 PM   #12 (permalink)
TN Pussy Man
basil is the guy who owns t-lex, so just ask for him when somebody picks up the phone.
also, try resetting the light by pulling the battery and it may at least let you drive the car to the shop...but I'm not too sure if that's a good idea either. CAA would probably be a good choice at this point lol.
HaHa
Old 03-16-2008, 10:16 PM   #13 (permalink)
i already resetted the code but no luck. i guess i ll call CAA tomorrow and tow it to T-Lex.
thanks .
Old 03-19-2008, 06:35 PM   #14 (permalink)
View Red Camry's Photo Gallery
does your car sound like its trying to start or just completely dead?
CAMRYcoupe
Red Camry is offline   Reply With Quote
Old 03-19-2008, 07:51 PM   #15 (permalink)
i've narrow it down to the starter solenoid and its not the camshaft position sensor (although i will be replacing it so the engine light goes away)
