Fault Code Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2008, 06:26 PM   #1 (permalink)
View urbnhilbily's Photo Gallery
Fault Code Help
Trying to help a friend I'm usually on the tacoma forum.
Friend took the car to autozone and recieved the following report.
"P1133 Manufacurer Contrl Fuel Air Metering and P1135 Manufacurer Contrl Fuel Air Metering and Also a P0301 Cyl 1 misfire detected" any help would be appreciated. I'm thinking maybe O2 Sensor, or dirty injector? Let me know what your guys know. Oh its a 99 LE 4cyl
urbnhilbily is offline   Reply With Quote
Old 03-10-2008, 08:32 PM   #2 (permalink)
View toyomoho's Photo Gallery
P1133 A/F sensor circuit response malfunction
P1135 A/F sensor heater circuit malfunction
P0301 Cylinder 1 misfire detected.
The first two codes point to a bad A/F sensor. The last code is a problem with this cylinder misfiring; most likely ignition system or fuel injector.
