front hood wont close on Gen 3 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2008, 08:42 PM   #1 (permalink)
torontotenor's Avatar
View torontotenor's Photo Gallery
3rd Generation front hood wont close on Gen 3 Camry
A friend of mine has a 93 Camry, he tried to close his hood after putting in some windshield washer fluid, it would only close to the semi locked position and subsequent to that his trunk release lost its springiness. We thought
that the cable might have been broken but you could still hear it moving near the latch in the hood. Anybody have any ideas about this? Thanks in advance.
torontotenor is offline   Reply With Quote
Old 03-10-2008, 10:10 PM   #2 (permalink)
View Kitto's Photo Gallery
Try some WD-40 first to see if that solve the problem.
Kitto is offline   Reply With Quote
Old 03-11-2008, 08:54 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You may have fixed it by now but also check the two rubber pads in the front corners. These adjust up and down (mine are cut with a spiral pattern and I just twist them). If they are too high up it might not close.
Kep
Old 03-12-2008, 09:12 PM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
hmmmm....front hood.....as opposed to what..a rear hood?
j/k
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 03-13-2008, 12:14 PM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i would spray some engine cleaner (or possibly brake cleaner, if you use it cautiously) to clean out the latch mechanism. mine constantly use to clog with debris and oil. once its cleaned, use some graphite spray to lubricate. this gives lubrication without the stickiness so debris wont continue to collect.
Old 03-13-2008, 04:06 PM   #6 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
j/k
haha
Go with what ghettosled said. one of my friends cars had the same problem and it turned out to be the latch getting stuck due to debris. Could be the hood bumpers like Kep said...all you have to do is adjust them by screwing them in or out. But if it was closing before, then it shouldn't be those unless someone adjusted them without your friend knowing haha.
As for the trunk release problem, mine has a similar problem. Sometimes the release latch opens it and sometimes it doesn't (also unlocking it with the key doesn't work at all haha). But it's probably something wrong with the spring judging by your blunt description (obviously). I think mine is the cable but who knows. Hope that helps.
Mazeraski is offline   Reply With Quote
