crazy idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2008, 10:23 PM   #1 (permalink)
View redoo2000's Photo Gallery
crazy idle
i pulled into my drive way and my car started idling between 1500 and 2000 rpms, then it stayed at 2000 rpms in park. i put it in drive and it dropped to 1100 rpms. i drove around and there was a slight hesitation on acceleration. i just did spark plugs, cap and rotor, wires, and pcv valve. last weekend. i shut the car off 2 times with no change, then the 3rd time it was back 2 normal at 750 rpms. what could be the problem??? 2.2l auto 96 camry le 4dr
100,000 miles.
redoo2000 is offline   Reply With Quote
Old 03-10-2008, 10:59 PM   #2 (permalink)
View 1996camry's Photo Gallery
the following things I would check
does the RMP go up and down while u're in Park or Drive (at dead stop)
1) make sure your throttle body clean (sure not stuck)..do a search on this forum for more info. clean throttle body
2) if the throttle body clean does not fixed your problem..
3) the (idle) sensor that control RMP to adjust accordingly near the MAP sensor on the throttle body go bad..
1996camry is online now   Reply With Quote
Old 03-11-2008, 08:38 PM   #3 (permalink)
i bought the car last week. i cleaned the throttle body with seafoam and air cleaner.. it was really dirty, the pcv valve was stuck open. it only did this yesterday.. never happened before
Old 03-12-2008, 02:03 PM   #4 (permalink)
View marc780's Photo Gallery
Maybe 96camry is right about the throttle body, if the butterfly is crudded up and sticking to the plenum this could make your crazy idle. Its easy to fix and it probably needs cleaning anyways so just clean it and see what happens
http://www.toyotanation.com/forum/t158097.html
