Having a hard time starting... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2008, 12:56 PM   #1 (permalink)
View Red Camry's Photo Gallery
3rd Generation Having a hard time starting...
It sounds like my car lately has been having a little trouble starting up. plugs and wires were replaced like 2.5-3 years ago, starter was replaced (with a used one) about a year ago.
I guess the way to describe it, is that its almost weak and doesnt have enough power to really turn over quick.
any ideas??
thanks!
CAMRYcoupe
Red Camry is offline   Reply With Quote
Old 03-11-2008, 01:27 PM   #2 (permalink)
View premierplayer's Photo Gallery
battery? bad ignition coil?
premierplayer is offline   Reply With Quote
Old 03-11-2008, 03:51 PM   #3 (permalink)
View toyomoho's Photo Gallery
If the engine seems to turn over faster when starting after driving for a time, might be battery is going bad. When engine is operating the battery is fully charged. If a dieing battery is allowed to set overnight it will loose some of its charge and have less cranking power. If the battery the situation will get worse over time.
Old 03-11-2008, 05:43 PM   #4 (permalink)
Battery is brand new.
Old 03-11-2008, 07:11 PM   #5 (permalink)
View TheNewbie's Photo Gallery
my car had that problem b4. Try stepping on the gas peddle when turning hte key. There might not be enough oil going to the engine. But mine was a gen. 4.
If u have been using the cheapest oil, start using the better one or use the fuel injection.
TheNewbie is offline   Reply With Quote
Old 03-11-2008, 07:29 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Following toyomoho's point, if it is turning over slowly there is too little power. Bad battery, poor electrical connection(s), or failing alternator. Would you be able to take it to an auto parts store to have them check the electrical system for free? Even if the battery was "new" it may have been on the shelf too long.
Kep
Old 03-12-2008, 12:06 AM   #7 (permalink)
Gameroom cash: $303055
^ What Kep said. Add one more simple possibility; a loose alternator belt. They can stretch out over time.
Mike
Old 03-12-2008, 01:59 PM   #8 (permalink)
View marc780's Photo Gallery
The others have some good ideas to fix the problem, heres a couple more suspects in case you draw a blank. the car might need new battery cables; or the ignition switch could be very worn and need replacing. Also examine the ground cable from the battery - make sure it is not correded away, that it is bolted firmly in place, and that the grounding point where it bolts to is shiny and not rusted too much.
Old 03-13-2008, 12:29 PM   #9 (permalink)
alright thanks guys
i also have no idea who that guy is who said my battery is brand new...
CAMRYcoupe
Old 03-13-2008, 01:22 PM   #10 (permalink)
Kep
Kep's Avatar
I just noticed that. That's curious. Maybe he meant to have a question mark at the end of the sentence instead of a period. When I first read it I figured it was the original poster, you.
Kep
