Help ASAP PLEASE......... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2008, 12:09 PM   #1 (permalink)
View J_Phu's Photo Gallery
3rd Generation Help ASAP PLEASE.........
I have a 92 camry doing a manual swap. Well the pressure plate is grinding against the bell housing and I"m thinking its becuase i used the shims off my flexplate. So is there a dif. in thickness for the shims in a flexplate and a flywheel??? If so, what thickness is recommended for my flywheel? I seem to have 2 options .25mm or .50mm.
Edit: Oh yeah I forgot to mention that its a v6 3VZ-FE
J_Phu is offline   Reply With Quote
Old 03-13-2008, 12:13 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
You're doing a manual swap or you completed the manual swap? Or is your (92 Camry) car doing a manual swap???? lol
If you just finished it, what transmission did you use and what pressure plate, flywheel and clutch disc did you use? (For which car)
RichieRichJP is offline   Reply With Quote
Old 03-13-2008, 12:21 PM   #3 (permalink)
LOL naw I'm the swap on my 92 camry. I'm almost finish with the project. Well I use an E153 from a v6 standard 97 camry. The flywheel I used was a 92 v6 camry, the clutch kit I used a 97 camry....but back to my does anybody know.....
Old 03-13-2008, 01:15 PM   #4 (permalink)
Ok, so you should have used a e153 clutch disc with a s54 pressure plate and flywheel. The issue you have has to do with the clutch kit. I believe the one you are using is thicker than the s54 one and needs to be milled (correct term?) down to fit properly.
I've read about a few people running into this problem on other forums.
Hope this helps
Old 03-13-2008, 01:32 PM   #5 (permalink)
wouldn't be becuase I'm using a shim that came off of a flexplate that causing the pressure plate to grind against the bellhousing? Using the s54 does sound like a good idea but my budget is very limited.
Old 03-13-2008, 04:10 PM   #6 (permalink)
*BUMP* Any suggestion, help...............
Old 03-13-2008, 09:42 PM   #7 (permalink)
PRSRIZD
MyFreeCamry's Avatar
iTrader Score: 6 reviews
View MyFreeCamry's Photo Gallery
Using a shim to move the flywheel further away from the engine and closer to the tranny??? if that is correct as to what you have done then no wonder you are hitting the tranny bellhousing....remove the shim!!!!!
1990 Yota truck - 2wd 4spd, 22r. Lowered 5", 17" Ford Escape rims, flat green paint.
1992 Camry - Going back to stock. GONE View my parts for sale - http://www.toyotanation.com/forum/sh...47#post2908847
MyFreeCamry is offline   Reply With Quote
Old 03-13-2008, 11:25 PM   #8 (permalink)
Ok so yeah, I just found out that the shim wasn't required when using a flywheel, as opposed to a flexplate. Thnx everyone for all the suggestions
