There are other things that result in no spark. If the above doesn't work, write back. If you want quicker answers you might want to run some searches on this forum and the Gen 1/2 forum. There will be a lot of posts that pertain to your situation.
I always ask, does your check engine light come on when first turn the key on (at that time that all the idiot lights come on to show that they are working)? It should.
Kep
