Low oil pressure/draining valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2008, 07:41 PM   #1 (permalink)
View davj3368's Photo Gallery
4th Generation Low oil pressure/draining valve cover
I recently replaced the o-ring on my 2000 Camry oil pump and, although the oil leak stopped, I now notice that in the morning my valves are 'dry' (clack for a few seconds on startup until oil is pumped in) and when the engine gets to around 3000 rpms I can hear the valves again.
Can someone tell me why this might be happening? I'm not losing oil, but it drains from the valve cover area (I'm assuming) and I apparently have low pressure...acts almost as if the oil strainer is clogging.
Anyway, I appreciate any input. I'm considering replacing the entire oil pump.
davj3368 is offline   Reply With Quote
Old 03-16-2008, 05:37 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
What is your oil pressure and how long does it take to build pressure on start-up?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-16-2008, 07:44 PM   #3 (permalink)
only takes a second or two to build up pressure. Like I said, i can only hear the valve cams for a second or two on startup...and when I get to over 2500 rpms. Not losing oil though...
Could having too much oil in the engine cause problems? Just curious....
Old 03-17-2008, 06:44 AM   #4 (permalink)
On an aftermarket gauge or with idiot light? I think idiot light only needs about 6-8 psi, it should almost go out immediately.
When you replaced the o-ring did you disassemble the oil pump gears? If memory is correct I think the driven gear can be reverse installed. That could be the problem as its wear pattern now does not fit with wear pattern of the driving gear. Also if you cleaned the gears and pump housing and did not use re-build grease on re-assemble that could have led to this problem as you would have had a dry start-up.
Old 03-18-2008, 03:22 AM   #5 (permalink)
Unco's Avatar
View Unco's Photo Gallery
do you have enough oil in the engine? check your oil level.
if that doesn't fix it --> did this problem only start straight after you put the new o-ring???
if the problem was there before you replaced the o-ring, you may just need to use slightly thicker oil... what mileage has the engine done?
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
