Half shaft removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2008, 08:25 PM   #1 (permalink)
View djsim1056's Photo Gallery
Half shaft removal
I got a 93' Camry attempted to remove passenger side half shaft and replace everything went well until I went to pull it out of the transmission. Seems the intermediate bearing it rusted in the cradle, lock bolt and snap ring are removed any ideas how this can be removed?
djsim1056 is offline   Reply With Quote
Old 03-16-2008, 01:36 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
lots of luck and a sledgehammer
long story short, the method that the shop manual gives about being able to "slide" the half-shaft out is a myth for just about any car that's been driven out of the factory and has seen any sort of salt/water/winter, etc.
some people have gotten lucky after spraying penetrating oil for a number of days/weeks and then hitting it from behind with a sledgehammer until i comes out....but most of us...either take it to a mechanic to drop the subframe and ease it out a different way, or pull the entire engine/tranny out to part it
the sledgehammer works for some....but then I'd change the carrier bearing for sure as well as inspect the differential for any damage since the pressure will be going on the half-shaft at an angle and may damage things with enough force and vibration
long story short....good luck
HaHa
Old 03-16-2008, 01:59 AM   #3 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
weld a beating post on it and hit the thing like a dead prostitute.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 03-16-2008, 05:44 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
If you're lucky about 2 hours of cuss'n, hammer'n, pry'n and soak'n with PB Blaster. If you get it out use anti-seize on re-assembly.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 03-16-2008, 11:42 PM   #5 (permalink)
View anti-seize's Photo Gallery
here's a pretty good site...
...although it is not a how-to.
It's about removing a seized bearing on the passenger side halfshaft using Kroil and a Silver Slapper.
http://standardmischief.com/blog/200...netrating-oil/
here's what a "silver slapper" looks like.
http://images.google.com/images?q=%22silver+slapper%22
anti-seize is offline   Reply With Quote
Old 03-17-2008, 10:36 AM   #6 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Haven't tried it on a half-shaft but my dad would make his own 'puller' using one end of a chain wrapped around the part and the other around something heavy. (Concrete block for example) Then you can throw or rapidly tug on the weight which takes up the slack and 'jerks' the part. (like a dog reaching the end of his leash) Same principle as the "silver slapper".
Dave's is offline   Reply With Quote
Old 03-17-2008, 01:21 PM   #7 (permalink)
TN Pussy Man
i.e. slide hammer....
all I would say is that you would need one helluva slide hammer to get that thing out...
HaHa
