auto trans shifting problem-help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2008, 10:00 PM   #1 (permalink)
View beige97camry's Photo Gallery
97 camry with auto (a140E). when driving normal does not want to shift into OD. the OD button is on. could this be a solenoid and if so which one??? what does the shift solenoid valve SL do???? fluid is good color, smell and at proper level. thanks. problem started early last month...wifie car.
beige97camry is offline   Reply With Quote
Old 03-18-2008, 01:02 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
How many miles on the engine? How often (milage) have you change the transmission fluid?
When you actuate the OD button does the "OD Off" message go on and off on the dash display?
Are any indicator lamps flashing?
Kep
Old 03-18-2008, 11:19 PM   #3 (permalink)
OD button works, 155k on trans fluid changed last at 140k.
Old 03-19-2008, 08:57 PM   #4 (permalink)
NBBADTOYS
View keisuke's Photo Gallery
when on the highway and u turn off O/D does the rev's increase
1997 Toyota Camry XLE V6- 308500 and counting
keisuke is offline   Reply With Quote
Old 03-20-2008, 02:38 AM   #5 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
It should because normally with O/D off, the car won't shift into 4th gear.
http://www.toyotanation.com/forum/t239011.html
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is online now   Reply With Quote
Old 03-20-2008, 08:28 AM   #6 (permalink)
engineer in training
Gameroom cash: $145055
The SL controls the torque converter lockup. Basically when the TC locks it behaves like a manual transmission with a clutch and power is no longer lost moving through the torque converter. You will only notice the RPMs drop about one or two hundred but shouldd definately feel a differnce in the gas pedal when you try to accelerate with it locked up. The vehicle speed will increase directly in proportion to the engine speed, instead of a small increase in rpms then an increse in vehicle speed.
You may not notice all this happening until you look for it though, most people don't
