Fuel Filter replacement in a 2001 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2008, 10:24 PM   #1 (permalink)
View 1fastRR's Photo Gallery
I've read that you need to pull the back seats and disconnect the fuel pump relay to release the fuel pressure in order to change the fuel filter. Has anyone crimped the inlet line and had a good result. Has anyone done changed theirs?
1fastRR is offline   Reply With Quote
Old 03-17-2008, 10:37 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
I just went under the hood and changed it. I spilled a bit of fuel, but not much.
As far as the inlet line goes, it's metal so if you crimp it, you're screwed.
2007 Camry 2.4L 5M
Old 03-17-2008, 10:40 PM   #3 (permalink)
Good post! Did you notice any gas mileage improvement?
Old 03-17-2008, 11:21 PM   #4 (permalink)
I did not keep track of it at that time. Ensure you use flare nut wrench not regular wrench to prevent screwing up the fuel line.
2007 Camry 2.4L 5M
