Originally Posted by sc4dahtrz
Does anyone have any information and/or diagrams on how to change out the engine and transmission mounts on a '98 Camry? Any help is greatly appreciated!
Thanks
Please search this forum. There are detailed instructions here. As far as I know,the information for gen 3-3.5 should translate for gen 4.
When I changed mine, I loosened the top bolt on the rear mount by using a deep well socket and two extensions and a universal so I was able to loosen it from the top of the engine. The top of the extension will stick out between the valve cover and the intake. This will give you room to get a breaker bar on it because sometimes the nut is frozen with rust. No brusied hands this way. Also, on the front mount, watch your rad. and don't poke a hole in it!
Bear.
