i would say that you should check into getting your ignition set changed out, its not very uncommon for something to go wrong inside of there. my car once wouldn't allow my key to turn at all(something just got stuck inside) so i went to the junkyard and ordered one (about $60) and put it in. although i have a different key to start my car than i do to unlock it, its not a big deal
the ignition set is where you slide in your key to start your car, an easy fix
the car i did this to was a 97, and you said yours was a 99, could be a similar problem
Dont hit poles its alot of work
