1993 Camry Cooling System problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2008, 02:01 PM   #1 (permalink)
View newharley's Photo Gallery
I have a 1993 Camry 4cyl automatic and i just installed a new radiator flushed and re-filled the cooling system. I believe that i have air locked in the system as i am getting very poor heat now? What's the best way to remove the trapped air now. I have tried running the car to warm with the radiator cap off and squeezing the upper radiator hose which seem to have helped some, but i'm still not getting full heat. I also have noticed that when the car cools off with the radiator cap installed that the upper radiator hose collapses until you release the pressure through the radiator cap.
newharley is offline   Reply With Quote
Old 03-18-2008, 02:35 PM   #2 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
There are some posts on this so a search may turn up something else. Think parking uphill, cap off the radiator, heater on full heat, run until warm (should see the coolant really flowing) and squeeze top hose is what I remember.
Dave's is offline   Reply With Quote
Old 03-18-2008, 03:07 PM   #3 (permalink)
Gameroom cash: $303055
^ +1. What Dave said. I would let the car idle like this for at least 45 minutes. Then add coolant as necessary and replace the radiator cap. If that upper hose is still collasping, replace that hose.
Mike
Old 03-18-2008, 04:20 PM   #4 (permalink)
View marc780's Photo Gallery
If burping it still doesnt give you hot air, change the thermostat cause maybe its stuck open
Old 06-11-2008, 08:39 PM   #5 (permalink)
View dadalior's Photo Gallery
Post
how to see coolant flowing???
dadalior is offline   Reply With Quote
Old 06-12-2008, 08:30 PM   #6 (permalink)
Look down the neck of the radiator. Remember, the cap is off during this procedure.
Mike
Old 06-13-2008, 12:55 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There may be a second problem. I don't believe that an air lock would explain the hose collapsing. That sounds more like the radiator cap or the tube to the overflow tank or the overflow tank itself has a blockage preventing the radiator to vent when it cools down.
I don't believe this would explain the lack of heat but I don't believe the lack of heat explains the collapsed hose either.
By the way, what is your temp gauge doing during all of this?
Kep
