Hello all,
I picked up a 1997 Camry LE "cheap"
(5 bills), I suspect main bearings are shot, (170,xxx) oil change shows "sparkles" non-magnetic. Oil pressure good till warm-up, then oil light(red oil can) flickers and stays on. Good news, just had a head, water pump, timing belt, and idlers replaced less than 500 miles ago.
1. Where is the best place to buy rings, pistons if needed, bearings and gaskets?
2. Where can I find Torque specs for Head, mains, and everything else?
3. Are there any tricks or special tips I should know before tearing into the 2.2?
4. Rack and pinion is leaking on the drivers side, best place to get a rebuild kit or overhauled unit?
Thanks again!
