Hi all,
First the facts: 1996 5SFE 4cyl engine with 196,000 miles.
Oil pressure light came on while driving. Engine runs smooth with
no tapping or other funny sounds. Replaced pressure sensor and
light still came on. Pulled oil pan off and looked at intake screen.
It was clean but I cleaned it and the oil pan too. Then I replaced the
oil pump with a Toyota factory pump. The oil light comes on intermittently
and now seems to be out. (for now...). I put a pressure gauge on the engine all through this process and was getting 0 psi at the gauge. Finally I ran some motor cleaner through it and blew about 100 psi of air back through the engine through the pressure sensor port. Now I'm getting about 17 psi at all
RPMs.
My Haynes manual says I should be getting 35-71 psi @ 3000 RPM. I'm still getting 17 psi.
Any thoughts or advice would be helpful. I'm starting to go crazy!
Thanks
Paul
