Gen 3 Camary Start Up And Shut Down - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2008, 07:56 PM   #1 (permalink)
View Spike23's Photo Gallery
Hey guys,
So my dad was driving the cam today, and he parked for a few mins and left the ignition key on the on so he could listen to some music after a few mins he started the car up. The car started up fine..but then few seconds shut down. Since i wasn't there..thats the best information i got from him.
My assumption is the alternator going bad...but i have yet to check..i prob need to go buy a volt meter and see what happens. Any suggestions peeps?
This is the first time this has happened.
Spike23 is offline   Reply With Quote
Old 03-25-2008, 07:38 AM   #2 (permalink)
campfire9's Avatar
View campfire9's Photo Gallery
When was the last time you checked out your battery? Check it while your at it because it may be at a stage that it won't hold a charge and that can happen all at any time.
campfire9 is offline   Reply With Quote
Old 03-25-2008, 08:28 AM   #3 (permalink)
View hooRAH's Photo Gallery
Unlikely that you have battery or alternator problems. If you had enough juice to start the car (and not notice that the car was cranking slowly), then you would have enough battery power to at least run the car for 30mins to an hour.
More likely I think you're describing a stall on warm startup, which is often caused by a dirty throttle body or idle air control motor. Might want to clean those out and see if it helps.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 03-25-2008, 11:11 AM   #4 (permalink)
Hmm this could be a reason.
How would i clean the throttle body?
Thanks for the feedback btw guys.
Old 03-25-2008, 11:11 AM   #5 (permalink)
Ya might check the battery too.
But not now since its still damn cold out.
Going to buy a volt meter sometime soon.
Old 03-25-2008, 12:02 PM   #6 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
If you have the 4 cylinder; Throttle Body cleaning
The V-6: TB cleaning
The 4 cylinder one was done on a 2000 Camry. I'm not sure how similar this is from generation to generation, so maybe someone else can answer that; I don't want to give you wrong information
Be sure to read the whole thread. Be careful while doing it though; sticking sharper objects like a screwdriver in there can scratch the coating or damage the throttle body, so watch out. Use something that won't cause this to happen. This is something I was thinking of doing myself sometime as well
If there is an Autozone or Advanced Auto Parts near you, they test the alternator and battery for free, although from the information you gave it doesn't sound like a battery problem at least.
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
