trans fluid change question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2008, 10:48 PM   #1 (permalink)
View beige97camry's Photo Gallery
just draining the trans pan...how many qts to refill and what is the total trans capacity including the converter? thanks.
beige97camry is offline   Reply With Quote
Old 03-24-2008, 11:12 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Um, car?
5 Lug Corolla WHAT?
Old 03-24-2008, 11:19 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
^ 97 duh (judging by his name)
Drain it and then go buy the same amount of quarts the came out...
Good luck draining the torque converter.
2007 Camry 2.4L 5M
Old 03-25-2008, 11:50 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Check owners manual for qty.
pick what engine you have, so you get the right transmission
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 03-25-2008, 12:42 PM   #5 (permalink)
View anti-seize's Photo Gallery
my 2.2 took about 1 and 1/2 quarts from draining just the pan. You'll need a 10mm hex to get the drain out. I apply upward pressure with the jack on the back of the breaker bar to get the drain bolt cracked (just for the first 1/4 turn). I don't want to "cam out" the drain bolt.
YMMV
just buy 3 quarts of ATF dex 3. It's ok to keep some on hand. Does not spoil.
1994 Camry, 5SFE, automatic trans., 233k (it's a beater)
anti-seize is offline   Reply With Quote
Old 03-25-2008, 01:03 PM   #6 (permalink)
Gameroom cash: $303055
If you have the 4 cylinder 2.2 5SFE engine, draining and refilling the pan takes 2.6 quarts. Draining and refilling the differential, which must be drained and refilled separately on the I4, takes 1.7 quarts. Be sure to use Dexron III.
Mike
Old 03-25-2008, 01:07 PM   #7 (permalink)
Darkside Cut Me!!!
To add, the diff on the 2.2 I4 has separate fill bolt, so be sure to open that first.
2004 RX330 Sport
2003 Cam I4 XLE
Old 03-25-2008, 03:12 PM   #8 (permalink)
thanks guys, my questions were answered. finally got a manual on order, it is 97 as sig said and is 2.2. thanks again.
Old 03-25-2008, 08:47 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Not a good idea...as you cant drive the car without the fluid in there
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 03-26-2008, 10:46 AM   #10 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
With how many miles are you doing this?
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 03-26-2008, 11:24 AM   #11 (permalink)
Darkside Cut Me!!!
I got my I4 camry with 60000 Kms, and it had drain and fill at 50 000 km service before.
I do drain and fill every summer regardless of KMs, but I average 40 000 to 50 000 km. a year.
2004 RX330 Sport
2003 Cam I4 XLE
Old 03-29-2008, 09:35 AM   #12 (permalink)
View gonesurfing's Photo Gallery
Measure what came out and put the same amount back in.
gonesurfing is offline   Reply With Quote
Old 03-29-2008, 10:42 AM   #13 (permalink)
Beautiful Central Oregon
skypros's Avatar
View skypros's Photo Gallery
4th Generation
Is there somewhere that explains how to do a Transmission flush on a '98 Camry V6 Auto
And can Mobil 1 ATF be used?
Is the sky the limit ?
1998 Camry XLE V6
2002 Tundra SR5 4x4
skypros is offline   Reply With Quote
Old 03-29-2008, 11:51 AM   #14 (permalink)
Darkside Cut Me!!!
Mobil 1 ATF Dex III/ Mercon is good, and I use it in my power steering as well.
But for a flush, do a search
I did use a less expensive fluid (if you will be doing that by yourself), for experience, timing etc. I used the walmart store brand for my initial flush of my V6, and know I was not wasting fluid with my set up of hose, connectors,transfer pump for filling and so forth. one of my connections came apart during my experience, so I now added zip ties to my list of things to prepare for in my head, if I do that again..
I now do yearly drain and fill with Dex IV. and that is it.
2004 RX330 Sport
2003 Cam I4 XLE
Old 03-29-2008, 06:31 PM   #15 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
Dex IV? you mean Dex VI, right?
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
