Gen4 DIY strut/spring install and removal? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2008, 12:17 PM   #1 (permalink)
datnguyen24's Avatar
View datnguyen24's Photo Gallery
4th Generation Gen4 DIY strut/spring install and removal?
Does anyone have a DIY for the Gen 4 install and removal? I am going to change my stock springs and blow shocks. Brought some Tokico Blues and H&R and was wondering is anyone has a DIY for the install. Or should I just take it out to pepboys or something? I know I need to realign after the install. Thanks.
datnguyen24 is offline   Reply With Quote
Old 03-25-2008, 01:25 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
i dont think there is a DIY for a spring/strut replacement.
i would advise doing it yourself since a shop will charge a alot of money to do it. its not hard, just time consuming. but ull need a Haynes or related manual, spring compressors, advise using a breaker bar, an assortment of sockets and wrenches. it would also be good to use a jack and kack stands but i have done this twice using the factory jack, but do so at your own risk.
if you replacing these parts you may also want to consider replacing the strut mounts and boots.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-25-2008, 04:01 PM   #3 (permalink)
View Undertow's Photo Gallery
Like Bigbird said, it is a smart idea to replace the strut mounts. The one thing that can be difficult (and a little dangerous) to do is compressing the spring to put on the strut. Most everything else is knowing which bolts and nuts to remove and where they are located. I would also advise using WD-40 or equivalent to prep all the bolts and nuts before removal, it makes things a lot easier to remove. When I did mine I had to buy a new sway bar link because the connection to the strut was too rusted and stripped.
'97 Grey Camry 5SFE 69,000 miles
Eibach Springs and Tokico Struts installed :]
Undertow is offline   Reply With Quote
Old 03-25-2008, 04:55 PM   #4 (permalink)
4th Generation
I brought the Tokico Blues and Red H&R springs from a member here on toyotanation. The springs are already attached to the struts and should arrive tomorrow all assembled. All I would have to do it directly bolt it on right? Sucks I wish I lived near someone who had a Camry they modded. haha. Yeah I called my local toyota dealer and they quoted me almost $600 in labor alone and thats if I brought my own shocks and springs. Do you usually torque the 3 top nuts under the hood? My brother in law has an impact gun and compressor but those suborn nuts are hard to take off so i'll invest in a breaker bar as well. Thanks guys if you have anymore tips that would be great.
Old 03-25-2008, 04:57 PM   #5 (permalink)
4th Generation
Oh I almost forgot is the rear hard to tackle? I didn't get a chance to take a look at the rears yet. How do I go about taking it off? remove the seats? or trunk?
Old 03-25-2008, 04:59 PM   #6 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
DIY: Gen 3 front struts
Should be almost the same for you.
5 Lug Corolla WHAT?
Old 03-25-2008, 08:40 PM   #7 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
tHATS a really helpful tread. you should invest in some new stabalizer bar links. beat they'll strip when you take 'em off. at least one of four will( if you've never taken them off before) so you might as well replace them. they're cheap anyways. then torque every thing to speck or it'll start to mak clicking noises or worse.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 03-25-2008, 08:47 PM   #8 (permalink)
^ haha, the links are the bitch of the whole thing.
Oh, and PLEASE get a can of PB Blaster and spray them ahead of time!
5 Lug Corolla WHAT?
Old 03-25-2008, 09:25 PM   #9 (permalink)
thanks for all the help guys going to tackle it this week or weekend. looking to replace my left front cv joint. making that annoying clicking sound on right turns. that should be an easy install too right? any knowledge is better than none thanks for all the help guys I appreciate it a lot
Old 06-02-2010, 09:58 AM   #10 (permalink)
View 4getr34's Photo Gallery
im also thinking about doing this my self, did op happen to create a diy for gen 4s?
4getr34 is offline   Reply With Quote
Old 06-02-2010, 10:46 AM   #11 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
What is about rear struts DIY?
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 10-30-2010, 11:01 PM   #12 (permalink)
figdogg22's Avatar
View figdogg22's Photo Gallery
Smile Rear Struts
Don't need it. Did the rear struts last night in my garage on my 97. Pretty easy job only suggestion is to spray the shit out of those bolts before you try to take them off; especially if they've never been taken off.
My car developed this annoying noise on every bump so it was time to swap them out. The suspension feels way better now.
figdogg22 is offline   Reply With Quote
Old 10-31-2010, 12:07 AM   #13 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Check the dates on threads before you post! This one is pretty old.
'07 Honda Ruckus Big Bore
