Parking Lights Front side marker - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2008, 08:35 PM   #1 (permalink)
View psyanyde's Photo Gallery
Hey guys
Got a question..
A little while ago (2 weeks or so) my drivers side parking/front side marker light went out.
I thought it was a bulb fuse.
So I went to Canadian Tire and got a new set of bulbs. Replaced them and still nothing.
I replaced both sides (changed colours too)
but the drivers side one is still not working.
next I thought it could be the fuse, so I took out the manual and looked up which fuse it could be.
It says it's #26 TAIL 15A but that also covers a few other lights which all work, so it's prolly not the fuse.
Should I still check the fuse? (had to run into work where I am now and will be till 7am so I couldn't do it right away)
Any ideas?
1993 Camry V6 LE 4 Dr - 236K as of Feb 2008. All Stock.
psyanyde is offline   Reply With Quote
Old 03-25-2008, 09:27 PM   #2 (permalink)
Proud Toyota Owner
CamryWilly's Avatar
View CamryWilly's Photo Gallery
time to get that old voltmeter out of it's dusty state!!!
Check everywhere starting at your bulb contact and try to test at different locations if you can and see where the problem resides!
Maybe water got stuck in there....
William
CamryWilly is offline   Reply With Quote
Old 03-26-2008, 10:27 PM   #3 (permalink)
Alright, is there another thing that I can check without checking for the current?
i just don't have any access to a volt meter right now until the weekend
Old 03-27-2008, 12:37 AM   #4 (permalink)
Unco's Avatar
View Unco's Photo Gallery
not really. i wish electrical problems were as simple to fix as just replacing a fuse. unfortunately, that's not always the case.
check the globe holder and clean it up. it may just be dirty/loose.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-27-2008, 11:28 AM   #5 (permalink)
View anti-seize's Photo Gallery
Umm, test light? That's just a known good bulb with some wire leads. Without either a meter or a test light the only options I see you having are 1) change the bulb, see if it works, 2) change the fuse, see if it works, or 3)physically inspect the wire for cuts or breaks.
Connect one end of your test light to the negative terminal of the battery. Touch the other end to the positive post to see if your test light still lights.
Now with the negative terminal still connected to the battery, probe the test points on top of the fuse. Your light should light on both test points. If it does, you have confirmed that the wiring is good up to the fuse. If it only lights on one test point, then you have a bad fuse.
Continue, using similar methods, to probe the socket for the side marker bulb itself. if you have power there, you know the wiring is good, else you know that there is a break somewhere between the fuse and the bulb.
1994 Camry, 5SFE, automatic trans., 233k (it's a beater)
anti-seize is offline   Reply With Quote
