Hey guys, I was changing the front motor mount on my "new" used 93 V6 Camry Wagon, and because I had just did a oil change, like a idiot, I didnt remove the oil filter. I was able to get a ratchet on the 17mm bolt, until it sliped and took out the white sensor connected to the front of the block, about 1 inch to the left (passenger side) and 1 inch below the oil filter. Im guessing its a oil temp, engine water temp, or crank sensor. I went ahead and cranked the car over, and the check engine light came on and it sparked 1 once and then protected itself and wont fire anymore.
Can someone please identify this part, again, stock v6 (3vzfe) 1993 Camry Wagon. And its a white plastic body...
Thanks, luckly it snaped at the sensor and not the connector, so I can just re-attach when it I get the replacement. Looking at it, its got a weird round connector holding it in, does a special socket fit, or some sort of channel lock type device? Its obvious I am going to have to pull the oil filter, and why that is off, I will torque the engine mount bolt as well, since like I said, I was being a DUMB ass.
At 6' 2" and 274lb my big ass dont fit in alot of areas on this thing...
Septic
