Accessory power plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2008, 09:15 AM   #1 (permalink)
Beautiful Central Oregon
skypros's Avatar
View skypros's Photo Gallery
Is there a way to make the accessory power plug always ON vs only on when the key is in the ignition.
On my '02 Tundra, I was able to pull the relay for the accessory power plug.... and jam a small piece of paper making the relays contacts always closed
I don't see where the accessory plug relay is (although there sure are allot of fan relay in the car )
Is the sky the limit ?
1998 Camry XLE V6
2002 Tundra SR5 4x4
skypros is offline   Reply With Quote
Old 03-27-2008, 10:19 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Direct wire it from the battery (don't forget to use an inline fuse). Direct wire to the supply side of its fuse (if there are any other items sharing its fuse they will all be on with the key off).
Kep
