what does overdrive and driving pattern selector do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2008, 07:29 PM   #1 (permalink)
View saoxcore's Photo Gallery
i drive a 95 camry xle v6.
saoxcore is offline   Reply With Quote
Old 03-27-2008, 11:40 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
overdrive is your 4th gear, and the ECT button makes your tranny shift at higher rpms
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 03-27-2008, 11:48 PM   #3 (permalink)
Banned
View Vagisimo's Photo Gallery
IMO,
Overdrive off allows you to accelerate quicker at highway speeds
ECT on allows quicker acceleration from low speeds
Vagisimo is offline   Reply With Quote
Old 03-28-2008, 12:48 AM   #4 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
+1
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 03-28-2008, 12:50 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
ECT(PWR): delays shift till near or at redline allowing the crappy automatic tranny to actually use the RPM range(somthing i miss in my gen4).
overdrive: cruising gear, turn it off an u have a 3 speed and will eat gas and be no faster at ANY speed. for the gen3 owners, the only thing that should be used is teh PWR switch since it will hold the shift even going from 3rd to O/D.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-28-2008, 02:18 AM   #6 (permalink)
Banned
you should use OD on to save gas
and OD off to drop into 3rd gear to pass people, or for engine braking
as long as youre not going too fast for 3rd gear
never use PWR mode unless you are racing, it just revs the engine higher and accelerates at the same speed unless the gas pedal is floored
Old 03-28-2008, 02:23 AM   #7 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
Originally Posted by Black95Cam View Post
+1
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is online now   Reply With Quote
Old 03-28-2008, 09:19 AM   #8 (permalink)
Noob
View gladis's Photo Gallery
lol, this means that you can drive "manually" in an auto Camry!
L = 1st
2 = 2nd
D = 3rd
OD = 4th
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
gladis is offline   Reply With Quote
Old 03-28-2008, 09:39 AM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
that is 100% backwards. you never want to use over drive selection as a means to pass people or for engine braking. over drive is created as a simple cruise gear, put your fpott down and the car will shift out of O/D for you.
PWR was created for merging and passing by allowing conservitive the transmisson to take advantage of the power in the higher RPMs. its not for racing, just make the car a little, sportier, well call it. and it does not accelerate the same. turn it on and it will hold shifts longer, even at light throttle. the point in the rpm range where it shifts is dependent on throttle position. i suggest you read the owners manual because it explains what PWR is for.
R.I.P.
Car Domain:
Old 03-28-2008, 05:53 PM   #10 (permalink)
so i dont get it... do i use overdrive when im just driving around, or do i use it once im at a certain speed or what?
Old 03-28-2008, 06:02 PM   #11 (permalink)
xet
View xet's Photo Gallery
keep it on 99% of the time under normal conditions
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 03-28-2008, 06:23 PM   #12 (permalink)
I HAS BOOST!!!
bigbird's Avatar
^ what the said, use the PWR to have your fun.
R.I.P.
Car Domain:
Old 03-29-2008, 12:56 AM   #13 (permalink)
'_'
Touge Star
'_''s Avatar
Just keep overdrive on, you won't really need to turn it off ever. O/D off is basically used for slower speeds. I guess you can manually shift with the automatic, but you still don't have total control over the shifting. For instance, you could be at a dead stop with the shifter in 2nd, but the car will still start in 1st gear. It also won't shift immediately into 2nd from 1st gear with the shifter, unless you were to let off the gas a little bit when accelerating. L and 2 are used for engine braking (ie. going downhill for long distances, shift into one of those gears to help save the brakes).
山道だいすきです。
Old 03-29-2008, 01:37 AM   #14 (permalink)
Banned
3rd gear is bad, mmm kay
dont use it, cause it is bad
ECT, O/D, and Rev Limiter. READ BEFORE YOU LOOK LIKE A TOOL PLEASE!
